Managing Users
From the Setup & Configuration → UsersClosed Represents a set of login credentials and contact information for an external user. A user is associated with an account. Once created a user should get privileges granted to act: - at an account level - at an organization level tab, you can view, add, edit, and delete users associated with organizations. You can also reset 2FAClosed Required login security using email or mobile verification. for users from this page. You can accessClosed Assets/abilities associated with default or custom roles. this page from the Manage Orgs and Users option in the Automox consoleClosed Our web-based management dashboard, available at https://console.automox.com..
Viewing Users
You can view the following details about users from the Users page:
Users Table
Description
Email
Email address of the user
First Name
First name of the user
Last Name
Last name (surname) of the user
Status
  • Active: the user account is active
  • Pending Invite: the user was invited, but has not yet accepted
  • Unassigned: the user account is active, but they have no role assignment
2FA
This shows the setting for two-factor authentication for this user. This can be email or mobile.
Actions
Options available:
  • Edit User
  • Remove User
Adding Users to Organizations
You can add users to organizations and select corresponding account, global, or organization-specific roles from the Users page.
Prerequisites: You have Account Administrator, Full Administrator, or Users: Invite permissions for the specific organization you want to add users to.
  1. Click Add User.
  2. On the Add User page, enter the email address for the user you want to add.
  3. Select if the user should have an Account or Global role.
    • These types of global roles mean the user has this same role for any organization available within the account.
  4. Under Organization, you can assign the user a role that is organization-specific (not global). See Guidelines for Single Organization RBAC Management.
  5. You can add the user to multiple organizations and assign multiple roles.
  6. Click Save.
Note:
  • A user who is new to the account receives an invitation to join the organization. The status of the user's account shows as Pending Invite until the user responds. The details for the user remain incomplete until the invitation is accepted.
  • Existing users to the account do not receive an invitation.
Editing Users
You can modify user details from the Users page. See Understanding Roles and Permissions for details about the types of roles and corresponding permissions.
  1. You can access the Edit User page in two ways:
    1. Click the email address of the user you want to edit. The Edit User page opens.
    2. Go to the Actions column and click Edit User.
  2. From here you can remove an assigned role, assign a new role, or make changes to organization assignments.
  3. Click Save.
Note:
  • When a user has an active account, but no role, the status shows as Unassigned.
  • If a user wants to use a different email address, they must first be removed from the organization and then invited using the new email address. This requires a user with permissions to delete and invite users.
Deleting Users
You can remove a user from an organization's account from the Setup & Configuration → Users page.
Note:
  • When you remove a user, they are removed from all organizations they had access to.
  • You cannot remove the only Account or Global Full Administrator.
Find the user you want to remove:
  1. Select the user(s) that you want to remove.
  2. Click the Actions button.
  3. Click Remove User.
  4. Confirm the message to delete the user.
Resetting 2FA
You can reset 2FA for a user from the Users page.
  1. Select the email for the user or users you want to reset 2FA for.
  2. From the Actions drop-down menu, click Reset 2FA.
Export Users
You can export a CSV containing a list of users. You can choose from the following fields (they are all selected by default):
  • ID
  • Email Address
  • First Name
  • Last Name
  • RBAC Roles
  • 2FA
How to Export Users
  1. Select the users that you would like to export from the users table.
  2. Click Actions.
  3. Select Export Users.
  4. Choose the fields that you want shown in the CSV.
  5. Click Export User.
