Managing Organizations
You can manage organizationsClosed A subset of an account. An Automox customer account can be tied to multiple organizations, and users can be invited to, and access multiple organizations. An organization contains users, devices, and policies. from the Setup and Configuration page. To access this page, select the Global ViewClosed Centralized interface for managing multiple organizations under a single account. (Manage Orgs and Users) button at the top right of the Automox console.
Prerequisites:
Note: You cannot remove an organization from the console. For help, submit a request in the Automox help center.
An organization is a collection of the devicesClosed A subset of Assets, a general term denoting anything that runs the Automox Agent and is registered with the system. of a company’s IT infrastructure. UsersClosed Represents a set of login credentials and contact information for an external user. A user is associated with an account. Once created a user should get privileges granted to act: - at an account level - at an organization level can be given a roleClosed A named descriptor of default or custom permissions/access that can be associated with a user for interaction with the platform within or across organizations. to access an organization with certain permissions. These permissions are then only related to the devices in that organization. A user can therefore be assigned different permissions for different organizations. (See Understanding Roles and Permissions.)
Viewing Organizations
The Organizations page shows all available organizations.
Prerequisities: You must have Organization: Read permissions.
The following information is available from the Organizations table:
Organizations Table Column
Description
Name
Name of the organization
Organization UUID
This is the universally unique identifier (UUID) associated with the organization
Organization ID
This lists the integer associated with the organization (org ID)
Created
Time and date that the organization was created
Modified
Time and date when the organization was updated or changed
Created by
Email address of the user who created the organization
Users
Number of users added to the organization
Devices
Number of devices added to the organization
SAML
Shows if SAML is enabled or disabled for the user
Status Shows if this organization is enabled or disabled
Account UUID This is the unique identifier for the Account. This column is hidden by default.
Global Organization UUID This is the global-level Organization UUID. This column is hidden by default.
Actions
Edit Organization: You can modify the organization name and manage user roles assignments for this organization
Adding Organizations
You can configure organizations based on the needs of your company’s IT structure.
Prerequisites: You have Account Administrator or Organization: Create permissions. See Understanding Roles and Permissions
Follow these steps to add an organization.
  1. From the Organizations page, click Add Organization.
  2. Enter a name for the organization and click Create Organization. Account and global full administrators are automatically added to a new organization during the initial setup.
    Note: The maximum name length is 45 characters. See Naming rules.
  3. (Optional) To add users at the organization level only, go to Organizational Level Roles and select the email address from the Add User list. See also Managing Users.
  4. Select the role for the added user.
    Note: Account and global full administrators are automatically added to a new organization during the initial setup.
  5. Click Save.
Naming rules
  • Maximum Length: The organization name must not exceed 45 characters.
  • Allowed Characters:
    • Letters: Uppercase and lowercase (A-Z, a-z)
    • Digits: 0-9
    • Special Characters: Underscore (_), hyphen (-), pipe (|), comma (,), apostrophe ('), and space
  • Prohibited Characters: Any character or symbol not listed above is not allowed.
Editing Organizations
You can modify organizations from the Edit Organization page.
Prerequisites: You have Account Administrator, Full Administrator, or Organization: Manage permissions. See Understanding Roles and Permissions
Follow these steps to edit an organization.
  1. Go to the Organizations page.
  2. You can access the Edit Organization page in two ways:
    • Click the name of the organization you want to edit, or
    • Go to the Actions menu (...) and click Edit Organization.
The Edit Organization page includes the following sections:
Details
This section provides an overview of the information listed on the main organization page, but for this one organization. You can find the following details about this organization:
  • Account UUID, Global Organization UUID, Organization UUID, Organization ID, Creation Date, and number of users associated with this organization listed by role level.
  • You can modify the organization name here.
Account Roles
This lists all account-level roles associated with this organization. To modify these, go to the Roles and Permissions tab.
Global Roles
This lists all global-level roles associated with this organization. To modify these, go to the Roles and Permissions tab.
Organization Level Roles
This lists all users and their assigned roles for this individual organization. From here you can take the following actions:
  • Add a user and assign a corresponding role or roles
  • Modify the role for an existing user
  • Remove a user. (Click the x next to the user to remove them from this organization.)
  • Confirm any modifications.
Note:
  • When you remove a user from a specific organization, it does not remove the user from the company account.
  • A user may be listed multiple times if they are assigned multiple roles within the same organization.
