Managing Global Keys
From the Setup & Configuration → Keys tab, you can view the Account UUID, Global Organization UUID, and manage Global API keys.
Global API keys
Credential for programmatic access to the Automox platform. differ from organization
A subset of an account. An Automox customer account can be tied to multiple organizations, and users can be invited to, and access multiple organizations. An organization contains users, devices, and policies. API keys in scope:
- Global API keys: Provide access across all organizations in an account
The account acts as the main object to store and manage all of the organizations under the account, including specifying the enabled modules, features, billing settings, etc for each organization.
- Organization
- Users
- Privileges User / Role / Organization
- Billing & contact information
- Card details
- Payment mode. They are managed at the global level and are useful for automation or integrations that need to span multiple organizations. - Organization API keys: Provide access only within a single organization. They are managed at the organization level and are useful when access should remain limited to one organization.
Global API keys reduce the need to create and maintain separate organization-level keys when you need cross-organizational access
You must meet the following requirements before you can create or manage global API keys:
- You are a Full Administrator or have a global custom role with Organization: Read and Manage permissions.
- You have All API Keys: Read, Modify, List, and Delete permissions.
API keys should be kept secure and not shared to prevent unforeseen changes or potential security issues. Never email or write down your API key.
Viewing Keys
Go to Setup & Configuration → Keys to access the Global Key Management page. The following information is available on this page:
- Account UUID: The UUID for the account. The account name is listed with this unique identifier.
- Global Organization UUID: The UUID required when using global API keys across all organizations in an account.
You can copy both UUIDs using the clipboard button.
- Global API Keys: The Global API Keys table lists all global API keys created for the account. How you view or interact with these keys depends on your permissions. See Global API Key Permissions and Actions for details.
Use the global API key to access the Automox API.
Global API keys allow administrators to authenticate and manage resources across multiple organizations in an account. What you can do with these keys depends on your assigned permissions.
- To view (decrypt) an API key, click the Show button to the right of the hidden characters. The key automatically hides again after 10 seconds.
- To copy the API key, click the Copy button (clipboard) to the right of the field. It is automatically decrypted.
Listing Global API Keys
You can list or view global API keys if you have the correct permissions.
- To list all global API keys, you must have All API Keys: Read permission.
- To view (decrypt) your own API key, you must have Personal API Key: Manage permission.
Adding Global API Keys
You can create up to 10 global API keys per user account.
- To add a global API key for yourself, you must have Personal API Key: Manage permission.
Steps to add a global API key:
- Select Add.
- Enter a unique name for the key.
- (Optional) Select an expiration date.
- Select Create.
Enabling and Disabling Global API Keys
You can enable or disable (modify) global API keys if you have the correct permissions.
- To modify global API keys for any listed user, you must have ALL API Keys: Modify permission.
- To modify global API keys from your account, you must have Personal API Key: Manage permission.
Deleting Global API Keys
You can permanently delete global API keys.
- To delete global API keys for any listed user, you must have ALL API Keys: Delete permission.
- To delete your own API keys, you must have Personal API Key: Manage permission.
Example Scenarios
This table provides examples of what actions are available in the Global API Keys table based on user role and assigned permissions.
| Scenario | Permission | Decrypt | Enable/Disable | Delete |
| User on their own key | Personal API Key: Manage | Yes | Yes | Yes |
| Admin on another user’s key (Modify only) | All API Keys: Modify | No | Yes | No |
| Admin on another user’s key (Delete only) | All API Keys: Delete | No | No | Yes |
| Admin on another user’s key (Modify and Delete) | All API Keys: Modify and All API Keys: Delete | No | Yes | Yes |
