Global Session Expiration Settings
You can customize the console time-out period for each organizationClosed A subset of an account. An Automox customer account can be tied to multiple organizations, and users can be invited to, and access multiple organizations. An organization contains users, devices, and policies.. To access the global session settings, go to the Manage Orgs and Users → Setup & Configuration page.
Prerequisites: You are an Account or Full Administrator or you have Users: Modify permissions. See Understanding Roles and Permissions.
Session Expiration
You can view and configure the default settings for session expiration (also known as console timeout) from the Settings tab.
Maximum Session Lifetime
The maximum session lifetime is the amount of time that a session can exist before the session is terminated and the userClosed Represents a set of login credentials and contact information for an external user. A user is associated with an account. Once created a user should get privileges granted to act: - at an account level - at an organization level must log in again. The maximum is 90 days (2160 hours).
The default maximum session timeout is 12 hours.
Idle Session Timeout
The idle session timeout is the amount of time a session can exist without user input (inactivity) before the session is terminated and the user must log in again. The maximum is 30 days (720 hours).
The default idle session timeout is 30 minutes.
Configuring Session Expiration
You can edit the default settings for the session expiration.
  1. To change the default settings for session expiration, click in the hours and minutes fields and enter the desired settings.
  2. Click Update to save the changes.
