Managing Devices
From the DevicesClosed A subset of Assets, a general term denoting anything that runs the Automox Agent and is registered with the system. page, you can view your inventory, assign a device to a groupClosed Represents a concrete grouping of devices. Every device must be assigned to a single group. A group contains settings for the following: - refresh interval - OS auto-update, apply and remove tagsClosed An optional label for custom device categorization and filtering., scanClosed The process of re-inventorying a device for patches and software., restart, export details, and remove a device.
Viewing Device Inventory
The following information is available from the Devices page:
Table Column
Description
Status
This column shows details about any status associated with a device. For example, it can show the last time a patch was processed, if the device is up-to-date, if a patch is scheduled, and if the device has been excluded from reports.
OS
This is the OS type of the device, either macOS, Windows, or Linux, which is depicted with an icon.
Device Name
This is the name that the device either assigns by default, or the name the user assigned to the individual device. Hover over the name of the device and click to open the detail view. See also Device Details.
Disconnect Time
The date and time that a device last disconnected from the platform. Note: Sort using this column, with the oldest at the top, to identify decommissioned devices. You can then remove the devices from the console.
Group
The associated group membership is displayed here. See also Managing Groups.
Tags
Tags are optional. There is no character limit and no limit on the number of tags you can apply to a device.
IP Address
IP address assigned to the device. Hover over an entry to show all associated addresses.
OS Version
OS version currently installed on the device.
Scheduled Patches
This shows if there are any scheduled patches for this device based on the patch policies.
Needs Attention
This column shows devices that require action due to one or more of the following conditions: A new patch is detected, the device needs a restart to complete installation, or the device has not checked in for over 30 days.
Device ID
This number is the same as the server ID.
Disconnected For
The amount of time the device has been disconnected in days.
Last User Login
The login name of the user who last logged in to the device. (Note: This is dependent on the last scan run on the device.)
Active Directory OU
The active directory organizational unit filter path, if configured.
Total Patches
This shows the total number of patches installed on the device.
Agent Version
This field indicates what version of the Automox agent is running on the device.
Note: This column does not show immediately for existing devices. Use the Columns button to show the agent version for all devices.
Serial Number
This lists all serial numbers for the devices. This column is hidden by default.
Date Added
The date and time that the device was added. Hover over the text to view in UTC. This column is hidden by default.
Signing Certificate Status
This shows the status of certificates for the device.
Pending User Install
Indicates whether the device is currently in a pending state due to install notifications.
Note:This requires that Agent version 2.1.x or later be installed.
Pending User Restart
Indicates whether the device is currently in a pending state due to restart notifications.
Actions
The actions you can take on a device are the same as the Actions button above the table.
Device Status FAQs
ClosedWhy do I see “Pending User Install” or “Pending User Restart” instead of the usual compliance status?
These statuses indicate that the device is ready to proceed but is waiting on end-user action (either to start an install or complete a restart). They help you distinguish between technical issues and user-driven delays.
ClosedHow can I use the "Pending User Install" and "Pending User Restart" statuses?
You can use Pending User Install to:
  • Identify blocked installs: Filter or review devices in this status to see which devices are waiting on user action.
  • Adjust policy strategy: If many devices remain in this state, consider:
    • Shortening or extending the deadline window.
    • Updating notification messaging to improve response rates.
You can use Pending User Restart to:
  • Manage restart behavior: If many devices are in this state, you may want to:
    • Adjust restart deadline windows.
    • Update notification messaging to encourage timely restarts.
ClosedDoes this change how policies run?
No. These enhancements do not change policy execution behavior. They only improve visibility into when policy progress is blocked by user decisions or deferrals.
Closed Why don’t I see these new statuses or columns?
If any device in your organization is running Agent version 2.0 or earlier, the new statuses and columns are hidden. To enable this feature, ensure all devices are upgraded to Agent version 2.1.x or later.
Showing All Columns of Data
The default setting of the Devices page does not show all available columns. You can show more data or rearrange how the columns are presented.
  • Click the Columns button and select the checkboxes to show or hide columns.
  • You can rearrange the order of the data by dragging the column names to the desired position.
  • To see columns that are not in view, use the scroll feature at the bottom of the table. You can use the arrows on your keyboard to scroll from left to right.
Actions Menu
The Actions menu lets you take actions on a device or group of devices. You can use the list of actions in two ways.
  • From the Devices page, use the checkbox to select one or multiple devices and click Actions above the table. This allows for bulk actions.
  • Use the Actions column to apply these actions on an individual device. This requires that the Actions column is showing.
The following sections describe the individual actions you can apply to a device or multiple devices.
Assigning a Device to a Group
To assign a device or multiple devices to a group, follow these steps: (See also Managing Groups).
  1. From the Devices page, click the checkbox for the devices you want to assign to a group.
  2. Click Actions and select Assign To Group.
  3. In the Assign to Group window, click the Group drop-down list and choose the desired group.
  4. Click Assign To Group.
Applying Tags in Bulk to Devices
You can directly apply tags to devices from the Device Details page; however, that is only for one device. From the Devices page, you can now apply tags in bulk.
There is no character limit for a tag and no limit on the number of tags you can apply to a device.
From the Devices → Actions menu, you can apply multiple tags to multiple devices using Apply Tags. You can also create new tags during this process. Follow these steps:
  1. From the Devices page, select the individual devices that you want to apply tags to.
  2. From the Actions menu, select Apply Tags.
  3. You can select a tag or tags that are listed in the Apply Tags window, or you can directly create new tags to apply to the selected devices.
  4. Click Apply Tag.
  5. After you refresh the page, you can check the results on the Devices page. You can check by viewing the tags column and searching for any of the devices that this was applied to.
Removing Tags from Multiple Devices in Bulk
You can directly remove tags from devices from the Device Details page; however, that is only for one device. You can now remove tags from multiple devices in bulk from the Devices page.
From the Actions menu, you can remove multiple tags from multiple devices using Remove Tags.
  1. From the Devices page, select the devices that you want to remove tags from.
  2. From the Actions menu, select Remove Tags.
  3. Select the tags that you want to remove from the selected devices. This removes the tags from being associated with the devices. This does not necessarily remove the tags from the organization.
  4. You can also remove all tags that have been assigned to a set of multiple devices. In the Remove Tags window, click the top checkbox to select all tags listed. Click Remove Tags. Then the selected devices will no tags associated with them.
Scanning a Device
To scan a device, follow these steps:
  1. From the Devices page, click the checkbox for the devices you want to rescan.
  2. Click Actions and select Scan to scan the device. Automox sends the request and retrieves the latest status of the device.
Restarting a Device
To restart a device, follow these steps:
  1. From the Devices page, click the checkbox for the devices you want to restart.
  2. Click Actions and select Restart.
  3. When the confirmation dialog window opens, click Restart device.
Automox sends the request and immediately restarts the devices. This bypasses any user notifications.
Exporting Device Inventory
You can export data contained in the Device inventory for one or all devices.
Use the Export CSV button above the table to export data for all devices.
To export inventory data for an individual device, follow these steps:
  1. From the Devices page, click the checkbox for the device you want export data for.
  2. Click Actions and select Export.
    A CSV file is automatically downloaded to your computer.
Removing a Device
To remove a device from your Automox inventory, follow these steps. After removing a device, it is no longer managed by Automox. A removed device can be re-added by reinstalling the agent on that device.
  1. From the Devices page, click the checkbox for the devices you want to remove.
  2. Click Actions and select Delete.
  3. Confirm the device removal in the Remove Devices dialog box.
  4. You can also remove an individual device starting from the details page. See Device Details.
Note: If you remove a device that is offline, when it checks in again it uninstalls. The status shows as uninstall pending.
