Managing Exclusion Windows
Exclusion windows allow administrators to define specific periods when Automox does not run tasks such as patching, policy executionClosed When a policy runs on targeted devices per schedule., required software installation, workletsClosed Represents an automation script that can execute on a set of devices, consisting of evaluation and remediation code blocks. Worklets can be OS-specific or targeting a platform-agnostic language. on devicesClosed A subset of Assets, a general term denoting anything that runs the Automox Agent and is registered with the system., or device scans. By scheduling these controlled pauses, administrators can prevent restarts or other interruptions during critical business hours and maintain predictable maintenance behavior across devices. Each exclusion window includes configuration details such as its name, schedule type, duration, and associated devices. You can create exclusion windows from the Scheduled Windows page, and edit or delete them from the Exclusion Windows page.
Prerequisites: You must have Full Administrator, Operational Administrator, or a custom role with Scheduled WindowsClosed Defined time periods controlling when Automox runs policies.: Create, Read, Modify, or Delete permissionsClosed Actions associated with a default or custom roles. to manage exclusion windows. Other roles have Read-only access. See Understanding Roles and Permissions.
Exclusion windows apply to all policy types: Patch All, Severity, Patch Only, Manual Approval, Patch All Except, Advanced, as well as Worklets and Required Software policies.
Creating an Exclusion Window
You can create an exclusion window to prevent Automox from performing processes during a defined time period.
To create an exclusion window, follow these steps:
  1. Navigate to Manage → Scheduled Windows.
  2. Select Create Exclusion Window.
  3. In the Details section, complete the following fields:
    • Exclusion Window Name: Enter a descriptive name for the scheduled window.
    • Notes: Enter optional context or details about the purpose of the scheduled window.
    • Status: Select Active to enable the scheduled window, or Inactive to save it without applying it.
  4. In the Blocked Activities section, choose whether to block policy executions, device scans, or both, during the exclusion window.
  5. In the Schedule section, configure when the exclusion window takes effect:
    • Recurring: Select one or more months, occurrences, and days. For example, to create an exclusion window that occurs on the second Monday of June, select June, 2nd, and Mon. This setting applies to the second occurrence of Monday in the month, regardless of the calendar week.
    • One time: Specify a start date and time and an end date and time.
      • All times are displayed in either UTC or Local Time.
  6. Under Duration, specify how long the exclusion window lasts. The duration cannot exceed the selected start and end times.
  7. In the Assigned Devices section, select Edit and assign one or more devices. You can filter the list of devices by OS, Group, or Tags. You can also search for a specific device. When you are finished assigning devices, select Apply. Automox does not run tasks on these devices during the scheduled time.
  8. To save the exclusion window, click Create Exclusion Window.
When an exclusion window is active, Automox prevents affected devices from running tasks during the defined time period.
Editing an Exclusion Window
You can update details, scheduling, or device associations for an existing exclusion window.
Note: Before making any changes, check whether the exclusion window is in progress. Modifying an active window can cause scheduled policy runs to resume once the change takes effect.
To edit an exclusion window:
  2. Select the name of the exclusion window you want to edit.
  3. Update any necessary fields, such as Status, Blocked Activities, Schedule, or Assigned Devices.
  4. Save the changes.
Deleting an Exclusion Window
You can remove exclusion windows that are no longer needed.
Note: Before deleting an exclusion window, check whether it is in progress. Deleting an active window can cause scheduled policy runs to resume once the deletion takes effect.
To delete an exclusion window:
  2. Select the name of the exclusion window you want to delete.
  3. In the edit window click Delete Window.
  4. A pop-up window shows any affected devices and their corresponding groups. Review the affected devices and, if you are sure, select Delete Window.
  5. Another warning window allows you to make a final decision to delete it or not. Select Cancel or Delete Window.
Manual Overrides
You can override an active exclusion window if you have execution permissions. When you manually scan a device, run a policy, worklet, or required software task during an active window, Automox displays a confirmation dialog warning that the task falls within the exclusion window.
If you continue, the policy execution action is logged in both the Activity Log and the Policy Results Report as a manual bypass of the exclusion window. Device scans are updated in Device Details - Device Logs.
For Run Now / Fix Now, devices that are in an active exclusion window show as Unavailable.
