Scheduled Windows FAQ
The following answers address common questions about how interact with , , and manual actions in Automox. You can currently create exclusion windows, and additional window types might be added in the future.
Note: Blocking device scans will not prevent DCUs or inventory data from running or updating. That information is collected outside of a device scan and will not be impacted.
What types of activities can be blocked using exclusion windows?
Exclusion windows can now be configured to block policy execution, block device scans, or both, during an active window.
What happens if a policy is scheduled during an exclusion window?
If a policy’s scheduled run time falls within an active exclusion window, Automox prevents it from executing. The policy run is marked as Blocked in the Policy Results Report and logged as an Activity in the Activity Log, both displaying the reason identified as “scheduled within an exclusion window.”
What happens if a device scan is set to occur during an exclusion window?
If a device scan would normally occur during an active exclusion window, that device scan will not happen and device information reliant on a scan will not be updated. You would have to manually scan that device to see up to date information, or wait for the next planned device scan outside of the exclusion window.
What happens if a policy starts before an exclusion window begins?
If a policy or worklet has already started when an exclusion window begins, Automox allows the current task to complete but does not start new tasks until the window ends. The results show as Partial for the incomplete portions.
Can I manually run a policy during an exclusion window?
Yes. You can manually run a policy, worklet, or required software task during an active exclusion window if you have execution permissions. Automox displays a confirmation dialog before continuing. If you proceed, the action is logged in both the Activity Log and the Policy Results Report as a manual bypass of the exclusion window. Policy runs via Run Now / Fix Now cannot be run as a manual bypass of the exclusion window.
Do exclusion windows apply to all policy types?
Exclusion windows apply to all policy types: Patch All, Severity, Patch Only, Manual Approval, Patch All Except, Advanced, as well as Worklets and Required Software policies.
Are tasks queued to start after an exclusion window ends?
No. Tasks or policies scheduled during an exclusion window do not automatically run when the window ends. They wait for their next scheduled cycle.
What happens if I edit an exclusion window while it is in progress?
If you change an exclusion window that is currently in progress, your changes take effect immediately. Modifying an active window can cause scheduled policy runs to resume once the change takes effect.
What happens if I delete an exclusion window that is in progress?
Deleting an active exclusion window immediately removes its restrictions. Policies or other scheduled work that fall within that time period can run once the deletion takes effect.
What time zone do exclusion windows use?
All exclusion window times are displayed and scheduled in either UTC or Local Time.
What happens when an exclusion window activates while a policy is executing?
- If the current package being installed is a third-party package, the installation completes and no further packages are installed.
- If first-party updates are downloading but have not yet started installing, no first-party updates install.
- If first-party packages have started installing, all first-party updates complete but no further packages are updated.
- If a patch requires a restart, the device does not restart and remains in a Needs Restart state until the command is triggered again.
