Data Extracts
A Data Extract allows you to access data such as historical patching and API activity in a download file. This describes how you can view, generate, and download data extracts from the Automox console.
Viewing Data Extracts
You can view previously created data extracts from the Data Extracts page.
  1. From the Reports page, click View for Data Extracts.
  2. If any data extracts are available, you can click to download them. If no extracts are available, you can generate a new extract.
  3. The Data Extracts table consists of the following columns:
Column name Description
Data Requested
Exact time and date when the extract was generated.
Date Range
Start and end dates of the requested extract.
Extract Expiration
Time and date the extract will no longer be available for download. After this date, the Status shows as expired. Note: Extracts are available for 24 hours.
Type
This shows which type of data extract was generated: Patch History or API Activity
Status
This can show the following statuses:
  • Queued
  • Running
  • Complete
  • Failed
  • Canceled
  • Expired
  • Note: The table can be sorted by Date Requested or Status.
  • Note: If you see a failed state, you can contact Automox Support by submitting a request through the customer portal. Provide the Data Extract ID so that Automox can help diagnose what went wrong.
Generating Data Extracts
You can generate an extract that provides details about patch activity or API activity for a defined time period.
  2. Click Generate New.
  3. Select the Extract Type you want to generate: Patch History or API Activity.
  4. Enter the start date and end date for the extract you want to generate. You can generate an extract that is a maximum of 90 days. This represents the 90-day time frame leading up to the day before the extract is issued. For example, on 2020-12-01 the default time-frame start should be 2020-09-02 and it should end with 2020-11-30.
  5. Click Generate.
    Note: This process can take several minutes.
  6. You can view the process and status of the new extract on the Data Extracts page.
Downloading Data Extracts
You can download and save data extracts that you have created.
Note: Extracts are only available to be downloaded for 24 hours after being created.
  2. On the Data Extracts page, find the extract you want to view and click Download.
  3. The extract (CSV) includes the following information for the time frame requested, depending on which type of extract:
What is in the download for each extract type?
Extract type: Patch History
Data Type
Exported Column Name
Meaning
Description
Device Information
device_name
Device Name
Name of device (typically hostname)
device_custom_name
Device Custom Name
Name assigned to the device by the customer.
organization_id
Organization ID
This is the organization ID
device_id
Device ID
This number is the same as the server ID
agent_version
Agent Version
Version of the Automox agent installed on the device
group
Group
Name of the group this device is assigned to
package_id
Package ID
Identifier for the specific package
device_ignored
Device Ignored
This indicates if a software package is ignored for a device (from the Device Details)
group_ignored
Group Ignored
This indicates if a software package is ignored globally from the Software page
Patch Information
patch_name
Patch Name
Name of the software update (patch)
patch_version
Patch Version
Version number of the software update
patch_knowledge_base
Patch Knowledge Base
Knowledge base identifier associated with the update
Mutual Device/Patch Information
operating_system_family
Operating System Family
OS family (Windows, Mac, or Linux)
operating_system_name
Operating System Name
OS name of the installed system
operating_system_version
Operating System Version
Installed OS version
managed_patch
Managed Patch
This shows if the update is managed by Automox
Event Data
event_timestamp
Event Timestamp
Timestamp of the event
patch_action
Event Type (patch action)
"Patch available" or "Patch installed"
patch_available_timestamp
Patch Available Timestamp
Timestamp that informs when patch became available for installation
patch_installed_timestamp
Patch Installed Timestamp
Timestamp that informs when patch was installed on the device
exposure_time_hours
Exposure Time
Amount of time the device was not updated with the available patch
Vulnerability Data
patch_severity
Patch Severity
Severity (if any) of vulnerability associated with the patch (for example: critical, high, medium, low)
cves
CVEs
CVEs (if any) associated with the patch
Extract type: API Activity
The CSV download includes the following exported data.
Column Name
Description
UUID
Universally unique identifier for the log entry
created_at (Creation Time)
Time and date that the extract was created
created_by (Created By)
Automox service that handled the request
environment
Automox environment the activity was logged in
organization_id
ID of the organization
user_id
ID of the user who made the request
identity_id
The ID of the identity used to make the request. For users, this is identical to the User ID field. For API keys, this is the ID of the API key used to make the request.
identity_type
The type of identity used to make the request (api-key, user)
request_id
Unique identifier for the request
method
HTTP method
path
URL path (for example: /api/servers)
content_type
Content-type header, if present
remote_ip
IP of the remote client who made the request
server_ip
IP of the server that handled the request
referer
HTTP referer, if present
query
HTTP query string
request_body
HTTP request body
response_code
HTTP response code
files
An array of the file ref objects that were uploaded in the request. Each file ref has the following fields:
  • Name: The original name of the uploaded file
  • Byte_size: file size in bytes
  • Hash: sha256 hash of file contents
