Using Automox Vulnerability Sync
From the Automate → Remediations page, you can organize vulnerabilities into Automox tasks.
Download a CSV-formatted Vulnerability Report
Follow the instructions in Exporting Vulnerability Scanner Reports to download a CSV-formatted vulnerability report from your third-party vulnerability scanner.
Viewing Remediations
Click the Automate tab and select Remediations → Manual.
Uploading a Vulnerability Report to Create Tasks
You can upload a CSV-formatted vulnerability report from a variety of different CSV providers and start adding tasks.
Note:
  • The maximum file size for CSV uploads is 1 million rows.
  • If you are accessing the Remediations page for the first time, you may see the options manual import or partner integration. Select the Get Started button for manual import and follow the steps here.
  • Using Notepad++ to open and save vulnerability scanner exports introduces hidden characters and can cause the manual import to fail. Automox recommends using a different source code editor.
  1. From the Remediations → Manual tab, click Import.
  2. Select the CSV provider format for the report that you want to upload.
    Note: The format required for the report is listed in the Expected Format field. Refer to that to ensure that the uploaded file meets the requirements (see also Exporting Vulnerability Scanner Reports).
  3. Click Upload File and select the CSV file you downloaded from the vulnerability scanner.
  4. If Automox determines the size of the file is acceptable, a confirmation shows that the file is accepted without errors and prompts you to click Next.
  5. A message then shows that it is processing the CSV. Click Finish.
Syncing the Imported Report
The mapping process is asynchronous. Therefore, it takes time to discover hostnames and any CVEs that they are impacted by. A sync is complete once it shows as Ready. Each CSV file has its own row and when the file completes processing it is highlighted. The remediations page consists of the following information:
Table Column Description
Name
Name of the CSV file that was uploaded
CSV Provider
Indicates the CSV provider source
Uploaded By
Email address of the user who uploaded the file
Status
Possible values:
  • Ready
  • Building
  • Error
Patchable Vulnerabilities
Number of vulnerabilities and affected devices that Automox can remediate
Unmatched Vulnerabilities
Number of vulnerabilities and affected devices in your environment
Unknown Devices
Number of devices that do not currently exist in your Automox organization
Updated
The date the file was uploaded
Actions
Options:
  • View Report
  • Delete
Remediating Vulnerabilities
You can view the Remediation Details page of any imported CSV file. This provides a detailed view of the specific vulnerabilities affecting your environment and options to remediate them.
  • From the Manual page, click the name of the CSV file to open the details page.
Identified vulnerabilities are automatically parsed into three categories:
  • Patchable Vulnerabilities
  • Unmatched Vulnerabilities
  • Unknown Devices
The Patchable Vulnerabilities tab lists vulnerabilities in packages that are grouped by severity. The package includes the CVEs and affected devices.
Note: This includes third-party vulnerabilities. Refer to Understanding Automox Severity Data for a list of software packages Automox supports updates for.
Each package includes a list of CVEs to remediate and a list of devices to patch. You can view the details by opening the drop-down menus.
Devices Table Column
Description
Device
Name of the device
Status
This shows the status of the device: For example, connected or disconnected.
OS
This is the OS type of the device: macOS, Windows, Linux
OS Version
OS build number
IP Address
IP address of the device
Remediation Status
Status of the vulnerability remediation for the specific device.
Remediation statuses include:
  • Not Started
  • In Progress
  • Success
  • Failed
  • Timed Out
  • Canceled
  • Click Remediate to install and patch the devices without a schedule.
  • After you click Remediate, the remediation status of each device updates as the policies are run. Open the Devices details for a visual depiction of the progress.
The Unmatched Vulnerabilities tab lists vulnerabilities and affected devices in your environment. These vulnerabilities require you to specify a worklet policy (see Creating a Worklet) in order to remediate the affected devices. You can view the detailed list of devices by opening the drop-down menu.
Description
Device
Name of the device
Hostname
Permanent device name
Private IP
Remediation Status
  • Click Remediate With Worklet to view a list of your existing worklet policies to remediate with.
Table Column
Description
Worklet Name
Name of the Worklet policy
OS
Supported operating systems by the policy
Notes
Click this icon to expand a section with notes about the policy
View Details
Click this link to open the Edit Worklet page for this policy in a new tab
  • You can use the search bar in the Remediate with Worklet window to find a specific worklet.
  • Click Remediate to schedule the worklet.
Unknown Devices
The Unknown Devices tab lists devices that do not currently exist in your Automox organization. This information can be used to identify gaps in your environment where the Automox agent is not already installed. The list of device hostnames can be exported and used in a tool like Automox Agent Deployer, which supports automatic deployment to CrowdStrike-managed devices.
  • Click Export CSV for a list of all unknown devices.
