Creating a Required Software Policy
The required software policyClosed Policy type that ensures that specified software is installed. distributes and installs software to the devicesClosed A subset of Assets, a general term denoting anything that runs the Automox Agent and is registered with the system. in your organizationClosed A subset of an account. An Automox customer account can be tied to multiple organizations, and users can be invited to, and access multiple organizations. An organization contains users, devices, and policies..
You must have the required permissions to perform this action. See Understanding Roles and Permissions.
By uploading an installation binary and setting the package name, installation command, and schedule, you can deploy software to an unlimited number of systems.
Note: The file size limit is 10 GB.
To create a required software policy, follow these steps:
  1. From the main console, click Automate → Policies.
  2. Click Create Policy.
  3. From the Create Policy page, go to the Required Software Policy section and select the corresponding OS for the policy you want to create.
  4. In the Policy Info area, configure the following:
    • Policy Name: Enter a name for the policy. This field is required.
    • Notes: Enter any notes, if required.
  5. (Optional) Set filters under Device Targeting, as needed.
  6. Complete the Scope section: (Note: These fields no longer auto-populate.)
    • Enter the required Package Name
    • Enter the Package Version
  7. Click Upload File to upload the installation file for the software update.
  8. Use the Installation Command field to create a script for the software installation. (Note: This field no longer auto-populates.) This is required if a script is not found on the device.
  9. In the Schedule area, set the patching schedule that runs on the device. The Schedule Preview provides a calendar view of the patching schedule. See Setting a Patching Schedule.
  10. (Optional) Associate this policy with a group by selecting the plus in the upper right of the page and selecting the desired groups. When the policy is saved, the group is then assigned to the policy.
  11. Click Create Policy.
