Tray Customization Worklets
This document provides guidance for using Automox Workletsâ„¢ to customize aspects of the Automox TrayClosed System tray application that works with the Automox Agent to deliver end-user notifications. experience on user devicesClosed A subset of Assets, a general term denoting anything that runs the Automox Agent and is registered with the system.. These worklets allow administrators to configure functionality beyond what is available in policy settings, such as defining a persistent message or enabling or disabling the tray interface. Automox will introduce additional customization worklets in future agent releases.
View Tray Management Worklets in the Worklet Catalog
Prerequisites:
Customize Trusted Message
This section describes two worklets that allow you to customize the message displayed at the bottom of the Automox Tray notification window. This static message helps users recognize that the notification is provided by an authorized IT administrator or service provider and is safe to act on. These worklets are available for both Windows and macOS.
The message supports up to two lines of text (approximately 75 characters total). Text beyond this limit is cut off. This configuration is not controlled through policy settings and must be applied using a worklet.
View in Worklet Catalog:
Remove Custom Trusted Message
To remove an applied custom message, update the text in the worklet or apply a new worklet with empty text to reset to the default messaging.
Enable or Disable the Automox Tray
This section includes two worklets that let administrators enable or disable the Automox tray on supported Windows devices. Disabling the tray prevents it from displaying to users, while enabling it restores its visibility. These settings are applied locally through the presence or absence of a control file and are not managed through policy.
Customize Tray Branding Icon
This section describes a new worklet that allows you to customize the system icon displayed on an endpoint. This icon, shown in the Menu Bar on macOS and in Window’s System Tray allows users to launch the Agent Tray. This customization helps deliver a more intuitive, professional, and tailored experience to end users.
Icon Requirements
  • Device must be running Agent v2.5.x or higher
  • File Types Supported: Only .png is currently supported
  • File Size (Pixels) Supported: Files must be 256 x 256 pixels
  • Both a Light Mode and Dark Mode file are required, with the following naming conventions; lightModeIcon.png, darkModeIcon.png respectively.
    • Note: On macOS, the tray icon updates automatically with OS theme changes. On Windows, the icon updates after an Agent restart or with certain Agent activity.
Customize Icon Tooltip (Windows Only)
This section describes a new worklet that allows you to customize the tooltip string that is displayed when hovering over the Agent icon in the Windows system tray. This enhancement is supported on Windows only at this time.
Tooltip Requirements
  • Endpoint must be running Agent v2.5.x or higher
  • Custom tooltip text must be 75 characters or less
  • Field supports UTF-8 character encoding
Customize Tray Title (Windows Only)
This section describes a new worklet that allows you to customize the title string in the Tray. This enhancement is supported on Windows only at this time.
Title Requirements
  • Custom title text must be 20 characters or less
