Moving Devices From One Organization to Another
Sometimes you must move a device
A subset of Assets, a general term denoting anything that runs the Automox Agent and is registered with the system. from one organization
A subset of an account. An Automox customer account can be tied to multiple organizations, and users can be invited to, and access multiple organizations. An organization contains users, devices, and policies. (org) to another within the console. This process involves two steps, both of which are performed directly on the target device.
You must have the required permissions to perform this action. See Roles and Permissions Management.
Manually moving a device
Manually moving a device to a new organization requires running just one command directly on the target device. The second step is to restart the device.
Update Agent Key
To move a device from one organization to another, you must update the access key the Automox agent
Lightweight client application, which is installed on managed devices. is using to the target organization. This can be done with the help of the --setkey option. This will deregister the device from the previous organization and set the agent key for the new organization.
- You must pass a string to the
--setkeyargument, even if it is an invalid key. - The access key passed cannot be the last one used.
sudo /usr/local/bin/amagent --setkey <NEW_ORG_ACCESS_KEY>Windows
C:\Program Files (x86)\Automox\amagent.exe --setkey <NEW_ORG_ACCESS_KEY>Linux
sudo /opt/amagent/amagent --setkey <NEW_ORG_ACCESS_KEY>Restart the Automox Agent
After setting the new organization access key, you must restart the Automox Agent service on the device using the following commands:
sudo launchctl bootout system/com.automox.agent
sudo launchctl bootstrap system /Library/LaunchDaemons/com.automox.agent.plistWindows
net stop amagent
net start amagentLinux
sudo service amagent restart
