Automox Okta Single Sign-on (SSO) Integration
You can configure single sign-on
Login via corporate identity provider. For example, Okta or Entra. through Okta for all your Automox users
Represents a set of login credentials and contact information for an external user. A user is associated with an account. Once created a user should get privileges granted to act:
- at an account level
- at an organization level.
Automox integrates with Okta Identity Management through a series of steps. Automox also has a pending application available on the Okta app marketplace. This supports both service provider (SP) and identity provider (IdP) initiated sign on. Users can either click the Automox app on their Okta dashboard to sign in, or provide their email address on the sign in page to be redirected to Okta for authentication.
Initial Setup
To set up Okta, you need the following information from Automox:
- Your unique ACS URL
- Entity ID
- From the Settings → Security tab in your Automox console
Our web-based management dashboard, available at https://console.automox.com., click Enable on the SAML
The standard for exchanging authentication data between an identity provider and Automox. option. - This loads a window with the required ACS URL and Entity ID.
Okta Configuration
As an Okta administrator, you can set up an integration to Automox following the normal Okta app creation steps.
- Within the Okta Admin panel, select Applications → Add Application.
- Search for Automox. If the application is not available, click Create New App.
- From the platform menu, select Web.
- For the sign on method, select SAML 2.0.
- On the General Settings window, enter a name for the app.
(Optional) You can right-click and save the following Automox logo and upload it.
- For the SAML Settings window, you need the customer ID (organization ID number) from the Automox console.
- Paste the Customer ID (this is the Org ID) into the Single sign-on URL field.
- Select the check box for Use this for Recipient URL and Destination URL.
- Paste the Entity ID into the Audience URI (SP Entity ID) field.
- The Name ID format should be Unspecified and the Application username Okta username.
- Automox supports custom attributes for first name and last name. To set these configurations, add an extra row in the Attribute Statements. The first row should include firstName in the first field, and
user.firstNamein the second field, while the second row should include lastName in the first field, anduser.lastNamein the second field. Note: To edit the attribute statements after initial setup, from the Okta developer dashboard, click Applications. Select the Automox Application and from the General tab click Edit on the SAML Settings section. Click Next and scroll down the page to find the Attribute Statements.
- From this page, you can download the Okta certificate that you can use to configure your application.
- After you finish the configuration, go to the application's settings page.
- Two options are available for configuring the integration.
- From the Sign On tab, click View Setup Instructions, which will open in a separate tab. From here, you can copy and paste the details required for Automox.
- Download the Okta certificate and import the XML file to Automox.
Automox Configuration
Follow these instructions for the Automox console configuration.
- From the Settings → Security tab in your Automox console, click Enable on the SAML option.
- In the Configure SAML window, paste the metadata based on the following mapping:
- Okta Identity Provider Single Sign-On URL = Login URL
- Okta Identity Provider Issuer = Entity ID
- Okta X.509 Certificate = x.509
- (Optional) You can provide a Logout URL that redirects users to a selected URL after logout. This is often a link to your internal Okta dashboard.
- Automox also supports auto-provisioning for new users. If enabled, you can add users to the Automox app in Okta, and Automox creates licenses for them as they attempt first login. When SAML is enabled, inviting new users to Automox is restricted to provisioning. This configuration is highly recommended.
- Click Save Configuration to enable SAML.
- Add all required users to the Automox app in Okta to complete your setup.
