Software Install List of Devices Using PowerShell
Use a PowerShell script to retrieve a list of devices that have a unique software package installed. This list includes the version number on the export file, but the search is done using the software package name.
This example output uses a search for Microsoft Edge Chromium:
Note: You must have the required administrative permissions to manage API keys. See Managing Keys for more information.
There are four areas in the code that you’ll need to update to get the script to function:
  • $orgID = 'YOUR_ORG_ID'
    You will need your Org ID, which can be found by looking at the URL. Select the value after the ?o=
  • $apiKey = 'YOUR_API_KEY'
    In your console, go to Settings → Secrets & Keys and select the API key.
    Note: The API key is per user. Each user will have a unique set of API keys.
  • $filePath
    You can also modify $filepath if you want to change the file name or save it in a different location. Keep in mind the script will overwrite a previously generated file if it exists.
  • $appInstalled = 'APPLICATION'
    Enter the name of the application as it is listed in the software section of a device’s page that has it installed. See Software Associated with a Device in Device Details.
Software List of Devices Script
Use this script to pull an inventory of devices that have a unique software package installed.
Copy
$appInstalled = 'Microsoft Edge'
$filepath = 'C:\Temp\AppInstalled.csv'
Set-Content $filepath -Value "Computer,Name,Version"
$apiTable = 'servers'
$orgAndKey = "?o=$orgID&api_key=$apiKey"
# Put components together
$getURI = $apiInstance + $apiTable + $orgAndKey
# Get the json body of the Web Request
# Convert to object with manipulatable properties/values
$servers = $servers | Sort-Object name
# Check each server for software
    $serverID = $server.id
    $serverName = $server.name
    $orgAndKey = "/$serverID/packages?o=$orgID"
    $response = (Invoke-WebRequest -Method Get -Uri $getURI -Headers $headers).Content | ConvertFrom-Json
    $installed = $response | Where-Object {$_.installed -EQ $true -and $_.display_name -EQ $appInstalled}
    $output = $serverName + "," + $installed.display_name + "," + $installed.version
    $output | Add-Content -Path $filepath
