Enforce Windows Registry Settings Worklet
This worklet
Represents an automation script that can execute on a set of devices, consisting of evaluation and remediation code blocks. Worklets can be OS-specific or targeting a platform-agnostic language. describes how to manage device
A subset of Assets, a general term denoting anything that runs the Automox Agent and is registered with the system. configurations through various registry settings, including 64-bit vs 32-bit registry access.
It is often valuable to change or enforce the behavior of a device by defining a particular registry value. The following is an example that can be extended to just about any setting that is useful to your situation.
Evaluate Current Setting
Before changing a setting, it is best to evaluate its current state before acting. Additionally, this allows the worklet to report Compliance to the desired state.
In this example, all you need to edit are the three variables you want to monitor/change. Set the path to the property, the name of the property, and the desired value. Use this as your evaluation code in your worklet:
# Define Registry Key and sub-value to evaluate
$regPath = "HKLM:\SYSTEM\CurrentControlSet\Control\Terminal Server"
$regProperty = "fDenyTSConnections"
$desiredValue = '1'
# Retrieve current value for comparison
$currentValue = (Get-ItemProperty -Path $regPath -Name $regProperty -ErrorAction SilentlyContinue).$regProperty
# Compare current with desired and exit accordingly.
# 0 for Compliant, 1 for Non-Compliant
if ($currentValue -eq $desiredValue) {
Exit 0
} else { Exit 1 }
The policy
Represents a set of logic statements that define the desired target state of a device, the allowed remediation schedule, and configuration parameters around how that remediation should take place. is marked as compliant/non-compliant based on the exit code
Numerical return value indicating script success (0) or failure (non-zero).. So a simple IF statement that exits accordingly is all that is needed to determine that state of the policy.
Remediating the Setting
After determining compliance, now it's time to act on that information. A non-compliant evaluation flags the device as needing remediation. So when the worklet's scheduled time arrives the device runs the remediation code. Here's the example that goes along with the evaluation above. Use this as your remediation code:
# Define Registry Key and sub-value to modify
$desiredValue = '1'
try {
Set-ItemProperty -Path $regPath -Name $regProperty -Value $desiredValue -ErrorAction Stop
Exit 0
} catch {
Write-Output "Unable to update $regProperty"
Exit 1
Again, just set the 3 variables to match the evaluation code. This will set the property to the your desired value. Success/failure here is determined again by the exit code. So a try/catch block is well suited to this scenario.
64-Bit Registry Workaround
Automox runs as a 32-bit process and looks at the 32-bit registry keys by default on a 64-bit device. This doesn't affect the current example, as it isn't looking in an affected registry locations, but this is worth noting for other scenarios.
For instance, all registry keys with a WOW6432Node counterpart (most commonly HKLM:\SOFTWARE) the 32-bit WOW6432Node counterpart will be read unless using the following workaround.
So HKLM:\SOFTWARE is interpreted as HKLM:\SOFTWARE\WOW6432Node if it is run as previously defined.
To get around this behavior, we can use the sysnative PowerShell.exe on the device. The following example uses a ScriptBlock to accomplish this. Note that some variables need to be defined inside the ScriptBlock as that code is run in its own context.
Evaluation
#### Check Registry with ScriptBlock
$scriptBlock = {
$currentValue = (Get-ItemProperty -Path $regPath -Name $regProperty).$regProperty
return $currentValue
# Define Desired Value here
$desiredValue = '1'
# Execute the ScriptBlock in a 64-bit shell,
# No need to assign to a variable if you don't
# have a return value. In most cases, you will.
$currentValue = & "$env:SystemRoot\sysnative\WindowsPowerShell\v1.0\powershell.exe" -ExecutionPolicy Bypass -WindowStyle Hidden -NoProfile -NonInteractive -Command $scriptBlock
Exit 0
} else { Exit 1 }
Remediation
#### Remediate Registry with Scriptblock
$scriptBlock = {
$desiredValue = '1'
try {
return 0
} catch {
return 1
## Since this block returns 0 for success and 1 for fail
## Use that value for exit code to determine success
$returnCode = & "$env:SystemRoot\sysnative\WindowsPowerShell\v1.0\powershell.exe" -ExecutionPolicy Bypass -WindowStyle Hidden -NoProfile -NonInteractive -Command $scriptBlock
Exit $returnCode
