About Worklets
Use the Worklet
Represents an automation script that can execute on a set of devices, consisting of evaluation and remediation code blocks. Worklets can be OS-specific or targeting a platform-agnostic language.™ option to perform any scriptable action on devices
A subset of Assets, a general term denoting anything that runs the Automox Agent and is registered with the system., including disabling a vulnerable process, managing native OS controls, mass rollback of patches
A software security or stability update., and moving unwanted applications.
Refer to Creating a Worklet for details:
- Automox Worklets 101
- See the Community discussions around worklet.
