Third-Party Patching Best Practices
Recommended best practices for managing third-party applications in Automox.
Patch Application Behavior Table
The following table lists the types of behavior for third-party software patching in Automox so that you can take actions, such as configuring groups and policies accordingly, if necessary. See also details about overrides in the section after this table.
| Software Title | App is NOT shut down in order to patch | App will NOT patch when running | App is shut down by vendor in order to patch | App is shut down by Automox in order to patch |
| 1Password 8 | ✔ (macOS) | ✔ (Windows) | ||
| 3Dconnexion 3DxWare | ✔ | |||
| 7-Zip | ✔ | |||
| 8x8 Work | ✔ | |||
| AbaClient | ✔ | |||
| ActivePresenter (v6-v10) | ✔ | |||
| Adobe Acrobat Classic (2020, 2024) | ✔ | |||
| Adobe Acrobat Pro DC | ✔ | |||
| Adobe Acrobat Reader 2020 Classic (MUI) | ✔ (macOS) | ✔ (Windows) | ||
| Adobe Acrobat Reader DC | ✔ | |||
| Adobe Acrobat Reader DC MUI | ✔ | |||
| Adobe Acrobat SCA DC | ✔ | |||
| Adobe Air (Harman) | ✔ (Windows) | ✔ (macOS) | ||
| Adobe Digital Editions | ✔ | |||
| Advanced IP Scanner | ✔ | |||
| Affinity Photo 2 | ✔ | |||
| Agent Ransack | ✔ | |||
| Ai2 Starter | ✔ | |||
| Aircall | ✔ | |||
| AirServer | ✔ (macOS) | ✔ (Windows) | ||
| Airtame | ✔ (macOS) | ✔ (Windows) | ||
| Algodoo | ✔ (macOS) | ✔ (Windows) | ||
| Alice 3 | ✔ | |||
| Altova MapForce Enterprise (2020, 2020R2, 2021R2, 2023) | ✔ | |||
| Altova MapForce Professional (2020, 2020R2, 2021R2, 2023) | ✔ | |||
| Altova MissionKit Enterprise (2020, 2020R2, 2021R2, 2023, 2024, 2024R2, 2025, 2025R2, 2026) | ✔ | |||
| Altova MissionKit Professional (2020, 2020R2, 2021R2, 2023, 2024, 2024R2, 2025, 2025R2, 2026) | ✔ | |||
| Altova XMLSpy Enterprise (2020, 2020R2, 2021R2, 2023, 2024, 2024R2, 2025, 2025R2, 2026) | ✔ | |||
| Altova XMLSpy Professional (2020, 2020R2, 2021R2, 2023, 2024, 2024R2, 2025, 2025R2, 2026) | ✔ | |||
| Amazon AWS VPN Client | ✔ | |||
| Amazon Chime | ✔ | |||
| Amazon Corretto (8, 11, 17, 18, 19, 21, 25) | ✔ | |||
| Amazon Corretto 8 JRE | ✔ | |||
| Amazon WorkSpaces | ✔ (macOS) | ✔ (Windows) | ||
| Anaconda Distribution | ✔ | |||
| Android Studio | ✔ (macOS) | ✔ (Windows) | ||
| AnyDesk | ✔ (macOS) | ✔ (Windows) | ||
| Archi | ✔ | |||
| Arduino IDE | ✔ | |||
| Artweaver Free | ✔ | |||
| Artweaver Plus 7 | ✔ | |||
| Asana | ✔ | |||
| ASAP Utilities | ✔ | |||
| Atlassian Companion | ✔ (macOS) | ✔ (Windows) | ||
| Atom | ✔ | |||
| Attendant Pro | ✔ | |||
| Audacity | ✔ (macOS) | ✔ (Windows) | ||
| Authy Desktop | ✔ | |||
| Auto Dark Mode | ✔ | |||
| Autodesk Design Review 2013 | ✔ | |||
| Autodesk Design Review 2018 | ✔ | |||
| Autodesk Desktop Connector | ✔ | |||
| AutoHotkey | ✔ | |||
| AutoIt | ✔ | |||
| AutoText Master | ✔ | |||
| AWS CLI v2 | ✔ | |||
| Azure Cosmos DB Emulator | ✔ | |||
| Azure Data Studio | ✔ | |||
| Azure Functions Core Tools | ✔ | |||
| Bambu Studio | ✔ | |||
| Bandicam | ✔ | |||
| Bandicut | ✔ | |||
| BankID | ✔ (macOS) | ✔ (Windows) | ||
| Beeftext | ✔ | |||
| Beyond Compare (v4, v5) | ✔ (macOS) | ✔ (Windows) | ||
| BIMcollab ZOOM | ✔ | |||
| BIMvision | ✔ | |||
| Bitvise | ✔ | |||
| Bitwarden | ✔ (macOS) | ✔ (Windows) | ||
| Blender | ✔ | |||
| Bloomberg Terminal | ✔ | |||
| Bluebeam OCR 20, 21 | ✔ | |||
| Bluebeam Revu 20, 21 | ✔ | |||
| BlueGriffon | ✔ | |||
| BlueJ | ✔ | |||
| BlueJeans | ✔ | |||
| Box Drive | ✔ (macOS) | ✔ (Windows) | ||
| Boxcryptor | ✔ (Windows) | ✔ (macOS) | ||
| Brackets | ✔ | |||
| Brady Workstation | ✔ | |||
| Brave | ✔ (macOS) | ✔ (Windows) | ||
| Breevy | ✔ | |||
| Bruno | ✔ | |||
| Bulk Rename Utility | ✔ | |||
| Bullzip PDF Printer | ✔ | |||
| Bytello Share | ✔ (Windows) | ✔ (macOS) | ||
| Caffeine | ✔ | |||
| CalDavSynchronizer | ✔ | |||
| Calibre | ✔ (macOS) | ✔ (Windows) | ||
| Camtasia (2018-2024) | ✔ | |||
| Canva | ✔ (Windows) | ✔ (macOS) | ||
| CCleaner | ✔ | |||
| CDBurnerXP | ✔ | |||
| Charles | ✔ | |||
| ChatGPT | ✔ | |||
| Cisco Duo Device Health | ✔ (macOS) | ✔ (Windows) | ||
| Cisco Jabber | ✔ | |||
| Cisco Jabber VDI Client | ✔ | |||
| Cisco Webex | ✔ | |||
| Citrix Workspace | ✔ (Windows) | ✔ (macOS) | ||
| Claude Desktop App | ✔ (macOS) | ✔ (Windows) | ||
| ClickUp | ✔ | |||
| CLion (2024.1, 2025.1, 2025.2, 2025.3) | ✔ | |||
| Clip2Net | ✔ | |||
| Clockify | ✔ (macOS) | ✔ (Windows) | ||
| Cloudflare Warp Client | ✔ | |||
| Cloudya with CRM | ✔ (macOS) | ✔ (Windows) | ||
| CMake | ✔ (Windows) | ✔ (macOS) | ||
| Cold Turkey Blocker | ✔ | |||
| Commander One | ✔ | |||
| ConEmu | ✔ | |||
| CPUID CPU-Z Classic | ✔ | |||
| CPUID HWMonitor | ✔ | |||
| CPUID Perfmonitor-2 | ✔ | |||
| Creality Slicer | ✔ | |||
| Creo View Express | ✔ | |||
| CryptoPrevent | ✔ | |||
| CrystalDiskInfo | ✔ | |||
| Cursor | ✔ | |||
| Cyberduck | ✔ | |||
| Datadog Agent | ✔ | |||
| DataGrip (2023.3, 2024.1, 2025.1, 2025.2, 2025.3) | ✔ | |||
| DAX Studio | ✔ | |||
| DB Browser for SQLite | ✔ | |||
| DBeaver Community Edition | ✔ | |||
| DbVis | ✔ | |||
| Deezer | ✔ | |||
| Dell Command Update - Windows Universal | ✔ | |||
| Dell Display Manager 2.x | ✔ | |||
| Dependency Agent | ✔ | |||
| Devolutions Remote Desktop Manager - Enterprise Edition | ✔ | |||
| Dialpad | ✔ (macOS) | ✔ (Windows) | ||
| Discord | ✔ | |||
| DisplayFusion | ✔ | |||
| DisplayLink Graphics | ✔ | |||
| Docker Desktop | ✔ (macOS) | ✔ (Windows) | ||
| Double Commander | ✔ | |||
| Draw.io | ✔ | |||
| Dropbox | ✔ (Windows) | ✔ (macOS) | ||
| Dropbox Capture | ✔ | |||
| Druva inSync | ✔ | |||
| DYMO Label | ✔ | |||
| Eclipse Temurin JDK 25 | ✔ | |||
| Eclipse Temurin JRE 25 | ✔ | |||
| Egnyte Desktop App | ✔ (Windows) | ✔ (macOS) | ||
| Ekahau AI Pro | ✔ (macOS) | ✔ (Windows) | ||
| Epson Easy Interactive Tools | ✔ | |||
| Evernote | ✔ (Windows) | ✔ (macOS) | ||
| Everything | ✔ | |||
| Exacqvision VMS Client | ✔ (macOS) | ✔ (Windows) | ||
| ezCheckPrinting 9 | ✔ | |||
| FileZilla Client | ✔ | |||
| FileZilla Server | ✔ (macOS) | ✔ (Windows) | ||
| Foxit PDF Editor (11, 12, 13, 14, 2025, 2026) | ✔ | |||
| Foxit PDF Reader | ✔ (macOS) | ✔ (Windows) | ||
| Garmin Express | ✔ (macOS) | ✔ (Windows) | ||
| GCompris Educational Software | ✔ | |||
| Genesys Cloud | ✔ (macOS) | ✔ (Windows) | ||
| Genesys Cloud Background Assistant | ✔ | |||
| GIMP | ✔ (macOS) | ✔ (Windows) | ||
| Git | ✔ | |||
| Git Extensions | ✔ | |||
| Github Desktop | ✔ | |||
| GitKraken | ✔ | |||
| GlassWire | ✔ | |||
| GNU Emacs | ✔ | |||
| Go Connect | ✔ | |||
| Go Programming Language | ✔ | |||
| GoodSync | ✔ | |||
| Google Chrome | ✔ (Windows) | ✔ (macOS) | ||
| Google Drive | ✔ (Windows) | ✔ (macOS) | ||
| Google Earth Pro | ✔ (macOS) | ✔ (Windows) | ||
| GoTo Connect | ✔ | |||
| GoTo Opener | ✔ | |||
| Gpg4win | ✔ | |||
| Grammarly Desktop | ✔ (Windows) | ✔ (macOS) | ||
| Graphmatica | ✔ | |||
| Greenfoot | ✔ (macOS) | ✔ (Windows) | ||
| Greenshot | ✔ | |||
| grepWin | ✔ | |||
| HandBrake | ✔ | |||
| HeidiSQL | ✔ | |||
| Hot Potatoes | ✔ | |||
| Hubstaff | ✔ | |||
| IcyScreen | ✔ | |||
| ideaMaker | ✔ | |||
| ImageGlass | ✔ | |||
| ImgBurn | ✔ | |||
| Inkscape | ✔ | |||
| IntelliJ IDEA Community Edition (2021.1, 2021.2, 2021.3, 2022.1, 2022.2, 2022.3, 2023.1, 2024.1, 2024.2, 2024.3, 2025.1, 2025.2) | ✔ | |||
| IntelliJ IDEA Ultimate (2021.1, 2021.2, 2021.3, 2022.1, 2022.2, 2022.3, 2023.1, 2024.1, 2024.3, 2025.1, 2025.2, 2025.3, 2026.1, 2026.2) | ✔ | |||
| IrfanView | ✔ | |||
| iTerm2 | ✔ | |||
| iTunes | ✔ | |||
| Jabra Direct | ✔ | |||
| JAWS 2022 | ✔ | |||
| KeePass (MSI) | ✔ | |||
| KeePass 2.x | ✔ | |||
| KeePassXC | ✔ | |||
| Keeper | ✔ | |||
| Leaklog | ✔ | |||
| LEGO Education SPIKE | ✔ | |||
| Lenovo Dock Manager | ✔ | |||
| LibreOffice | ✔ | |||
| LibreWolf | ✔ (macOS) | ✔ (Windows) | ||
| Logitech Bolt | ✔ | |||
| Logitech Options Plus | ✔ | |||
| Logitech SetPoint | ✔ | |||
| Logitech Unifying Software | ✔ | |||
| Mersive Solstice | ✔ | |||
| Microsoft .NET Runtime 10 | ✔ | |||
| Microsoft .NET Runtime 8 | ✔ | |||
| Microsoft .NET Runtime 9 | ✔ | |||
| Microsoft .NET SDK 10 | ✔ | |||
| Microsoft ASP.NET Core Runtime 10 | ✔ | |||
| Microsoft Azure CLI | ✔ | |||
| Microsoft Azure Storage Explorer | ✔ | |||
| Microsoft Edge | ✔ | |||
| Microsoft Office (2016, 2019, 2021, O365) | ✔ | |||
| Microsoft OneDrive | ✔ (macOS) | ✔ (Windows) | ||
| Microsoft OpenJDK (21, 25) | ✔ | |||
| Microsoft PowerBI Desktop | ✔ | |||
| Microsoft PowerToys | ✔ | |||
| Microsoft Project | ✔ | |||
| Microsoft Remote Desktop | ✔ (macOS) | ✔ (Windows) | ||
| Microsoft Skype | ✔ | |||
| Microsoft SQL OLE DB Driver 18 and 19 | ✔ | |||
| Microsoft SQL Server Management Studio 18, 19, 20, 21, 22 | ✔ | |||
| Microsoft Teams | ✔ | |||
| Microsoft Teams New | ✔ (macOS) | ✔ (Windows) | ||
| Microsoft Visio | ✔ | |||
| Microsoft Visual C++ Redistributable v14 (2015-2026) | ✔ | |||
| Microsoft Visual Studio Build Tools 2019, 2022 (Current, Spring 2023, 2022 LTSC & Fall 2022 LTSC) | ✔ | |||
| Microsoft Visual Studio Build Tools 2026 | ✔ | |||
| Microsoft Visual Studio Code | ✔ (macOS) | ✔ (Windows) | ||
| Microsoft Visual Studio Community 2022, 2026 | ✔ | |||
| Microsoft Visual Studio Enterprise 2019, 2022 (Current, Spring 2023, 2022 LTSC & Fall 2022 LTSC) | ✔ | |||
| Microsoft Visual Studio Professional 2019, 2022 (Current, Spring 2023, 2022 LTSC & Fall 2022 LTSC) | ✔ | |||
| Microsoft Visual Studio Professional 2026 | ✔ | |||
| Microsoft Windows .NET Desktop Runtime 10 | ✔ | |||
| Microsoft Windows .NET Desktop Runtime 6 | ✔ | |||
| Microsoft Windows .NET Desktop Runtime 8 | ✔ | |||
| Microsoft Windows .NET Desktop Runtime 9 | ✔ | |||
| Mozilla Firefox | ✔ | |||
| Mozilla Firefox Developer | ✔ | |||
| Mozilla Firefox ESR | ✔ | |||
| Mozilla SeaMonkey | ✔ | |||
| Mozilla Thunderbird | ✔ | |||
| MTPuTTY | ✔ | |||
| MySQL Connector/ODBC | ✔ | |||
| MySQL Workbench | ✔ | |||
| MySQL Workbench CE | ✔ | |||
| Node.js (20, 21, 22, 23, 24, 25, 26) | ✔ | |||
| NoMachine Enterprise Client | ✔ | |||
| Notepad++ | ✔ | |||
| Notion | ✔ | |||
| Nudge | ✔ | |||
| OBS Studio | ✔ (macOS) | ✔ (Windows) | ||
| Obsidian | ✔ | |||
| Octave | ✔ | |||
| ODBC Driver for SQL Server (17, 18) | ✔ | |||
| Omnissa Horizon Client 8 | ✔ (macOS) | ✔ (Windows) | ||
| OpenShot Video Editor | ✔ | |||
| OpenSSL | ✔ | |||
| OpenVPN Connect | ✔ | |||
| Opera | ✔ | |||
| Oracle Java (JRE) 8 | ✔ | |||
| Oracle Java SE 17, 18, 19, 20, 21, 25, 26 | ✔ | |||
| Paint.NET | ✔ | |||
| Pale Moon | ✔ (Windows) | ✔ (macOS) | ||
| Parallels RAS | ✔ (macOS) | ✔ (Windows) | ||
| Parallels Toolbox | ✔ | |||
| PDF Reader Pro | ✔ | |||
| PDF-XChange Editor | ✔ | |||
| PDF24 Creator | ✔ | |||
| PDFgear | ✔ | |||
| Perimeter 81 VPN | ✔ | |||
| pgAdmin 4 | ✔ | |||
| PictoBlox | ✔ | |||
| Pidgin | ✔ | |||
| Plantronics Hub | ✔ | |||
| Poly Studio (Lens) | ✔ | |||
| PostgreSQL 15 | ✔ | |||
| PostgreSQL 16 | ✔ | |||
| PostgreSQL 17 | ✔ | |||
| PostgreSQL 18 | ✔ | |||
| Postman | ✔ | |||
| Precision Transceiver Tool | ✔ | |||
| Proton VPN | ✔ | |||
| PuTTY | ✔ | |||
| PyCharm Community Edition (2024.1, 2025.1, 2025.2) | ✔ | |||
| PyCharm Professional (2024.1, 2025.1, 2025.2, 2025.3, 2026.1, 2026.2) | ✔ | |||
| Python 3.13 | ✔ | |||
| Python 3.14 | ✔ | |||
| QGIS | ✔ | |||
| QZ Tray | ✔ | |||
| R | ✔ | |||
| Recoverit | ✔ | |||
| RemotePC Host | ✔ (macOS) | ✔ (Windows) | ||
| RingCentral | ✔ | |||
| Royal TS 6 | ✔ (macOS) | ✔ (Windows) | ||
| Royal TS 7 | ✔ | |||
| RStudio Desktop | ✔ | |||
| RubyMine (2024.1, 2025.1, 2025.2, 2025.3) | ✔ | |||
| Seagull Scientific BarTender 2022 | ✔ | |||
| SecureCRT | ✔ | |||
| Sequel Pro | ✔ | |||
| ShareX | ✔ | |||
| Signal Desktop | ✔ (macOS) | ✔ (Windows) | ||
| SigWeb | ✔ | |||
| SizeUp | ✔ | |||
| Slack | ✔ (Windows) | ✔ (macOS) | ||
| Snagit (2018-2026) | ✔ | |||
| Snake Tail | ✔ | |||
| SoapUI | ✔ | |||
| Sourcetree | ✔ | |||
| Splashtop Remote Access | ✔ | |||
| Splashtop RMM | ✔ | |||
| Splashtop Streamer | ✔ | |||
| Splunk Universal Forwarder | ✔ | |||
| Spotify | ✔ | |||
| Steam | ✔ (Windows) | ✔ (macOS) | ||
| Sublime Text (v3 and v4) | ✔ | |||
| Tableau Desktop | ✔ | |||
| Talkdesk Atlas | ✔ | |||
| TeamViewer | ✔ | |||
| TeamViewer Host | ✔ | |||
| Tera Term | ✔ | |||
| Teradata Tools and Utilities | ✔ | |||
| TextExpander | ✔ | |||
| The Unarchiver | ✔ | |||
| TigerVNC | ✔ | |||
| TightVNC | ✔ | |||
| TortoiseGit | ✔ | |||
| TortoiseSVN | ✔ | |||
| Transmit | ✔ | |||
| Tunnelblick | ✔ | |||
| Twingate | ✔ | |||
| UltiMaker Cura | ✔ | |||
| VirtualBox | ✔ | |||
| Viscosity | ✔ | |||
| Vivaldi | ✔ (macOS) | ✔ (Windows) | ||
| VLC Media Player | ✔ | |||
| VMware Horizon Client 7 | ✔ | |||
| VMware Workstation Player | ✔ | |||
| VNC Server | ✔ | |||
| VNC Viewer | ✔ | |||
| WinMerge | ✔ | |||
| WinRAR (EN & FR) | ✔ | |||
| WinSCP | ✔ | |||
| Wireshark | ✔ | |||
| Wondershare Anireel | ✔ | |||
| Wondershare Creative Center | ✔ | |||
| Wondershare DVD Creator | ✔ (macOS) | ✔ (Windows) | ||
| Wondershare Filmora | ✔ | |||
| Wondershare PDFelement | ✔ (macOS) | ✔ (Windows) | ||
| Wondershare UBackit | ✔ | |||
| Wondershare UniConverter (13, 14) | ✔ (macOS) | ✔ (Windows) | ||
| X-Mouse Button Control | ✔ | |||
| XnView MP | ✔ | |||
| Yubico Authenticator | ✔ | |||
| YubiKey Manager | ✔ (macOS) | ✔ (Windows) | ||
| Zoom | ✔ (macOS) | ✔ (Windows) | ||
| Zoom Outlook Plugin | ✔ | |||
| Zoom Rooms (ZoomPresence on macOS) | ✔ (macOS) | ✔ (Windows) | ||
| Zoom VDI Client | ✔ | |||
| Zoom VDI Plugin | ✔ | |||
| Zulu JDK (8, 11, 16, 17, 18, 19, 20, 21, 22, 25) | ✔ |
Third-Party Overrides Options
The defined default patching behavior listed in the App will NOT patch when running column is intended to prevent patching of applications that are currently running. When this behavior is not appropriate for a given environment, you can choose to use a worklet to generate a local override file. After the overrides file is implemented, subsequent patch runs will honor the desired update behavior and force close the selected software titles. This is described in our Automox Worklets for Third-Party Overrides.
- Google Chrome for Windows (Product Name: “google_chrome”) can be configured for overrides even though it WILL patch when running. Setting this override will cause Automox to force close Chrome before patching so the new version is effective immediately.
You can access the Automox-approved Third-Party Override Worklets from the Worklets Catalog in the console:
- MacOS - Software Lifecycle - Manage Third Party Override Options
- Windows - Software Lifecycle - Manage Third Party Override Options
- Your account plan must include Worklets.
- You must have proper administrative privileges to access and manage Worklets.
