Cloning Policies
You can clone individual policiesClosed Represents a set of logic statements that define the desired target state of a device, the allowed remediation schedule, and configuration parameters around how that remediation should take place. from the Automate → Policies page. This allows you to create a duplicate, or clone, of a policy within the current organizationClosed A subset of an account. An Automox customer account can be tied to multiple organizations, and users can be invited to, and access multiple organizations. An organization contains users, devices, and policies. or to one or more other organizations.
This action clones the device targetingClosed Mechanism for targeting policies by device attributes., package targeting, schedule, and user notification configurations, if available. This does not clone the group settings. By default, the policy statusClosed Whether a policy is Active (On) or Inactive (Off). is always Inactive.
You can also use the Automox API to clone policies. Refer to the Automox Developer Portal for more information.
Prerequisites: You must have permissions to create policies for the organization you are cloning to.
In the console, follow these steps to clone a policy to one or more organizations:
  1. From the Policies page, find the policy you want to clone and select the Actions menu.
  2. Click Clone Policy.
  3. In the Clone Policy window, select the destination organization or organizations that you want to clone the policy to.
  4. Click Clone Policy.
    This creates a policy or policies with the prefix “Clone of” in the corresponding organizations that you chose to clone to. The name of the cloned policy also includes the time and date when the clone was created. Note: You can clone to the current organization.
  5. In the next window, you can select a policy to immediately view or edit. This cloned policy opens in a new browser window. This shortcut allows you to easily open cloned policies in the corresponding organizations.
  6. Click Done to return to the Policies page.
Note: Cloned policies require additional configuration before they are available to use. Select from the list of links in the cloned policies window to view each policy. You can also select the clone from the Policies page of the organization where it was created. Complete the desired configuration before you activate them. All cloned policies are inactive by default.
Example of a clone created in the current organization:
Completing the configuration of a cloned policy
From the Policies page of the organization where you cloned a policy to, you see the Name with the suffix “Clone of”.
In the previous example, the original policy is named Apply All Patches. The cloned policy is Clone of Apply All Patches. The new policy name includes the time and date of when the clone was created.
  1. To edit the cloned policy, click the name of the policy.
  2. In the Edit policy window, update the Policy Name. This must be a unique name within an organization.
  3. Edit the following fields, as required:
    • Change the Policy Status to Active.
    • To run the policy, you must associate groups with the policy. Click Associate Groups to assign groups to this policy.
    • Adjust the device targeting, package targeting, schedule, and user notifications, if applicable.
  4. Click Save Policy.
Searching for cloned policies
If you closed the window with the list of cloned policies, but you want to finish a configuration or remove a cloned policy, follow these steps to find the cloned policy.
  1. Go to the destination organization of the cloned policy.
  2. Enter “Clone” in the search bar.
All cloned policies appear in alphabetical order. You can decide to edit and save the clone under a different name, or remove the clone from the current organization.
Removing a cloned policy
You might want to remove a cloned policy that you no longer want to activate. This action removes only the cloned policy from the current organization.
  1. Go to the Policies page of the organization where the cloned policy is listed.
  2. Click Actions → Remove Policy.
  3. A warning message allows you to confirm the policy you are about to remove. Click Remove Policy.
Note: This action only removes a cloned policy from the current organization. It does not remove the same clone from other organizations.
