Understanding Restart Error Notifications
This article explains restart error notifications and provides examples that help you understand how to interact with them.
Important: This description applies only to devices with agents prior to Automox Agent version 2.1.x. For devices with Automox Agent version 2.1.44 or later, see End-User Notifications.
Allowing Notifications for macOS
Generally, notificationsClosed Configurable end user messaging sent by AXP. automatically appear according to your system settings. For macOS, you must allow notifications from the Automox Notifier.
To ensure you receive notifications for macOS, follow these steps:
  1. Go to System Settings (on older OSes, System Preferences) → Notifications → Automox Notifier.
  2. Enable Automox notifications.
  3. Select either Banners or Alerts.
Errors Occurring During the Restart Process
Errors can occur, for example, when an Internet connection fails. For failures during the final notification flow (as described in Managing End-User Notifications), the following types of notification messages can appear, depending on your OS.
Windows failure notification
Besides the final notice, if a restart fails, an error message appears. You are notified to restart the deviceClosed A subset of Assets, a general term denoting anything that runs the Automox Agent and is registered with the system.. This error message includes the policyClosed Represents a set of logic statements that define the desired target state of a device, the allowed remediation schedule, and configuration parameters around how that remediation should take place. name and ID for troubleshooting purposes. The following is an example of such a notification:
macOS failure notification
For macOS devices, when Automox notifications are enabled and the final notification flow fails, a System Restart Failure message is displayed. This error message includes the policy name and ID for troubleshooting purposes.
An example notification message can look like this:
  • You can right-click on the notification to view other native macOS options.
