Quick Start Guide - Patch Management in Minutes
You can be up and running using Automox patching policies in less than 30 minutes. Check out the step-by-step instructions to get you patching devicesClosed A subset of Assets, a general term denoting anything that runs the Automox Agent and is registered with the system. in no time.
Tips for Getting Started
Character Limits:
Keep the following character limits in mind when using the Automox ConsoleClosed Our web-based management dashboard, available at https://console.automox.com.:
  • Organization name - 45 Characters
  • API Key name - 45 Characters
  • Billing company name - 45 Characters
  • Group Name - 45 Characters
  • Policy Name - 100 Characters
  • Policy Cloning - 69 Characters
Add Devices
Before you can use the Automox console to manage devices in your organizationClosed A subset of an account. An Automox customer account can be tied to multiple organizations, and users can be invited to, and access multiple organizations. An organization contains users, devices, and policies., you must install the Automox agentClosed Lightweight client application, which is installed on managed devices.. You can download and install a single agent for all of your Windows, macOS, and Linux systems. At under 10 MB, the Automox agent is highly efficient with low I/O and CPU overhead. A persistent encrypted session with the Automox cloud securely manages your device. Follow these steps to install the Automox agent and add your devices:
  1. Go to Devices → Add Devices
  2. In the Add Devices window, select your OS and choose Download Installer.
  3. Download the installer file.
  4. Open the installer file to complete agent installation.
You can install the agent through an onboarding wizard. After adding your devices, Automox inventories all hardware, software, patches, and configuration details, which is visible from the Devices page.
Want to do more? Automox has several methods to install the agent in bulk across multiple domains or servers. You can read more about bulk deployment and other product use cases in our user documentation. This is also accessible by clicking the help question mark in the console.
Group Your Devices
Automox GroupsClosed Represents a concrete grouping of devices. Every device must be assigned to a single group. A group contains settings for the following: - refresh interval - OS auto-update enable you to segment your organization and simplify management. Whether you sort your devices by department, operating system, or region, groups simplify the management of your security infrastructure. Follow these steps to add a group, and assign devices:
  1. Go to Devices → Create Group
  2. Enter a Group Name for your new group.
  3. Click Create.
  4. In the Edit Group window, click Assign Devices to assign devices to the group. You can accept all other defaults for your new group.
  5. Click Update Group to save your group settings. After you create more than one group, you can look at the options that help you identify groups for easier management. And, as you become more familiar with Automox you can choose to customize your group settings.
Want to do more? Consider how you want to group and segment your devices for patching and endpoint hardening. You can create and assign policies to one group or multiple groups, and you also can choose to create sub-groups under a Parent Group for easier management.
Create a Policy
Policies automate cyber hygiene, helping you patch systems, ensure the right software is installed, and maintain configurations. You can create policies once and assign them to multiple groups of devices, quickly update policies for every device without the need to touch code or hardware, and create one policy to manage a mix of Windows, macOS, and Linux devices. To get you started, Create a Patch All policy:
  1. Go to Automate → Policies.
  2. Click Create Policy → Patch All.
  3. Enter a Policy Name for your new Policy and ensure the Policy Status is Active (On). This enables patching. You can accept all other defaults for your new policy.
  4. Before saving the policy, assign a group by clicking the plus sign in the Associate Groups section.
  5. Click Create Policy.
Want to do more? You can choose to configure the other policy settings at a later time such as: device filters, automatic restart, scheduling, user notifications, and deferral settings. These settings are not required for this quick start configuration, but are key for how you want to manage your devices long term based on your patching requirements.
Scan Devices and Run Policies, As Needed
Now that you've added your devices and assigned a policy to your specific group, manually scan your devices to determine their patching status.
Go to Devices → [Your Named Device] → Scan Device.
After scanning: If the policy status is non-compliant with the latest patches, you see a Needs Attention status. If the policy status associated with your device is compliant, then you're all set.
Under Associated Policies, you can choose to run a policy to put your devices in compliance with the latest patch updates. Click Run On This Device next to the associated policy.
Want to do more? You can customize the device scan interval to between 6–24 hours. You pick how frequently or infrequently you want Automox to scan the status of your devices. Be sure to check back regularly to see how your device statuses might have changed.
There's So Much More You Can Do in Automox
You've got the basics covered. Pretty simple, right? Here's a quick list of what more you can do to realize how Automox can make patching and device management easier:
  • Get familiar with the Automox dashboard. The Automox dashboard view provides full visibility into the statuses of your devices, allowing you to quickly identify misconfigured systems, missing patches, or compliance issues.
  • Add more devices and begin grouping them according to your patch management policies or organizational architecture. For example, group by department, operating system, or region. The ability to group your devices allows you to enforce specific policies according to your business needs.
  • Check for a software version in your application inventory. Because Automox provides access and visibility of all your devices, you can confirm that they are running the latest version of a specific software to keep them better protected and secure from known vulnerabilities.
  • Create a policy from a template using the Next Steps guide that appears in the console when onboarding. Automox recommendations establish a best practice 7-day cycle with basic (and customizable) policies.
  • Set a password policy across your available devices using an Automox Worklet. Automox leveraged cybersecurity best practices to create a worklet that lets you enforce these password policies across your devices: see Automox Worklet - Set Password Policies to create and run this worklet in your environment.
You can learn more about Automox Worklets at: www.automox.com/use-cases/worklet.
Manage Your Automox Subscription
Go to the Settings page in the Automox console, navigate to the Billing page, and pick the plan that works best for you. You can view more information about plan pricing at: http://automox.com/pricing
If you prefer, feel free to connect directly with your Automox sales representative to discuss the available subscriptions and discuss the best plan for you. You also can connect with Automox Sales at: sales@automox.com.
