Rolling Back a Patch
When patching, there might be times that rolling back a patch is necessary. Here are some steps and related information to that process.
Rolling back a patch is currently only available for Windows-based devices. If a patch offers a rollback option, refer to these instructions:
How to Roll Back an Installed Patch on Devices
Note: Not all patches can be rolled back.
  • Another option is to use the Automox Verified Worklet called Rollback Windows Patches.
  1. In the console, go to Automate → Worklet Catalog.
  2. Search for and select Rollback Windows Patches.
  3. Select the Code Preview arrow to open the Evaluation and Remediation Code details.
  4. This worklet is designed to remove one or multiple KBs from a device. Add KBs by placing the KB number (for example, KB1234567) between single quotes in the $KBNumbers variable.
If you want to block something that is released, refer to the following instructions. This reduces the remediation footprint.
