Account Management Using the Automox Console or PowerShell
Follow these best practices to clean up unnecessary user accounts.
Follow these steps to clean up unnecessary user accounts using the Automox console.
- Go to Settings ( ⋮ ) in the console.
- Select Users from the menu.
- Review the User Accounts list and select any unnecessary accounts.
You can also use the search bar to filter the list. - Select the Actions drop-down menu and click Remove User.
- Confirm the selected accounts so that only approved user accounts remain in the console.
Account Management Using PowerShell
Follow these steps to delete multiple users from an organization based on the user email addresses using a PowerShell script. This logs the successes and failures in a location that you specify.
There are four areas in the code that you’ll need to update to get the script to function:
$orgID = 'YOUR_ORG_ID'You will need your Org ID, which can be found by looking at the URL. Select the value after the
?o=
$apiKey = 'YOUR_API_KEY'In your console, go to Settings → Secrets & Keys and select the API key.
Note: The API key is per user. Each user will have a unique set of API keys.
$logPath
Set this variable to the folder where you want to save logs
$toDelete
Set your list of users you want deleted by their email addresses
Delete Multiple Users Script
### Replace the variables in this block with your Org ID & API key ###
# Modify log path as desired
$logPath = 'C:\Temp\'
# List of users identified by email to delete
$toDelete = @('user@email.com','user2@email.com','user3@email.com')
$page = 0
$limit = 500
# Easier to maintain, especially if multiple organizations, or for repurposing for different API Tables
$apiTable = 'users'
# Initialize empty arrays to store server IDs
$users = @()
$delList = @()
$failDelete = @()
$successDelete = @()
# Generate list of all users
while($true) {
$orgAndKey = "?o=$orgID&api_key=$apiKey&l=$limit&p=$page"
#put components together
$uri = $apiInstance + $apiTable + $orgAndKey
$resp = (Invoke-WebRequest -Method GET -Uri $uri -UseBasicParsing).Content | ConvertFrom-Json
$users += $resp
$page += 1
if($resp.count -lt $limit) {
break
# Narrow down to list of users that need to be deleted
ForEach ($user in $toDelete) {
$match = $users | Where-Object {$_.email -EQ $user}
$delList += $match
# Delete designated users. Log whether successful or failed to delete.
ForEach ($delUser in $delList) {
try {
$id = $delUser.id
$email = $delUser.email
$name = $delUser.firstname+' '+$delUser.lastname
$url = "https://console.automox.com/api/users/$id"+"?o=$orgID"
Invoke-WebRequest -Method Delete -Uri $url -Headers $headers
$successDelete += @{"Email"=$email;"ID"=$id;"Name"=$name}
Write-Output "Successfully Deleted User: $email"
catch {
$failDelete += @{"Email"=$email;"ID"=$id;"Name"=$name}
Write-Output "Failed to Delete User: $email"
# Output logging into json files for later review/manipulation
$successDelete | ConvertTo-Json | Out-File $logPath\Delete_Success.json
$failDelete | ConvertTo-Json | Out-File $logPath\Delete_Failed.json
