Policy and Filters, and Policy Scheduling
Using Scheduling (POST /policies and PUT /policies)
Policy
Represents a set of logic statements that define the desired target state of a device, the allowed remediation schedule, and configuration parameters around how that remediation should take place. schedules
The act of defining the date & time that a given policy would run. Ex: setting a Patch All policy to run every Monday morning at 5am, for the group(s) that the policy is assigned to.
Alternately, a plan for carrying out a process or procedure, giving lists of intended events and times. are the decimal value of a binary representation of True/False for each day/week/month.
Example Days per Week
For scheduling days of the week, there are 7 digits with a trailing zero to mark the end. This starts on Sunday and ends on Monday. 1 represents ON and 0 represents OFF for each day of the week.
Sun|Sat|Fri|Thu|Wed|Tue|Mon|TrailingZero
Every Day: 11111110 = 254
Mon/Wed/Fri only: 00101010 = 42
Example Weeks per Month
Weeks are scheduled similarly to days, except there are 5 digits with a trailing zero. This starts on the 5th week of the month and ends with the 1st week of the month.
5th|4th|3rd|2nd|1st|TrailingZero
Every Week: 111110 = 62
2nd/4th weeks only: 010100 = 20
Example Months per Year
Months continue the trend with 12 digits with a trailing zero. Starting with December and ending with January.
Dec|Nov|Oct|Sep|Aug|Jul|Jun|May|Apr|Mar|Feb|Jan|TrailingZero
Every Month: 1111111111110 = 8190
Mar/Jun/Sep/Dec = 1001001001000 = 4680
Advanced Filters
The following filter parameters are valid for advanced filters. Anything else returns a 400.
| Left Values | Condition Values | Right Values |
| display-name | contains, does-not-contain |
text string |
| severity | is, is-not, less-than-or-equal-to, greater-than-or-equal-to |
other, none, low, medium, high, critical |
| patch-source | is, is-not |
windowsupdate, opera, mozilla, adobe, oracle, apple, microsoft |
| patch-os | is, is-not |
windows, mac, linux |
| type | is, is-not |
upgrades, updates, update-rollups, service-packs, security-updates, tools, guidance, feature-packs, developer-kits, definition-updates, critical-updates, connectors, application |
| patch-days-old | is, is-not, less-than, less-than-or-equal-to, greater-than, greater-than-or-equal-to |
Integer between 1 and 180 |
Device Filters - Filter Parameters
The device filters preview allows you to view a preview of devices matching a set of Device Targeting criteria that you define. This correlates to the Device Targeting parameters in the Policy Editor screen available in the UI.
You can then use the same parameters to create a new policy, or update an existing policy, targeting those devices.
See the above sections for more info on Using Scheduling and Advanced Filters.
| Field | Supported Operators | Value Type |
os_family
in, not_in |
In, not in: list of strings |
os_version_id
in, not_in |
In, not in: list of integers |
ip_addr
like_any, not_like_any |
List of strings |
tag
like_any, not_like_any, in, not_in |
List of strings |
hostname
List of strings |
organizational_unit
List of strings |
Operators Used in API vs. Operators Used in UI
Effective July 22, 2022, for improved usability, the operators used for Device Targeting Filters in the UI will be changed. The operators used for Device Targeting Filters in the API have not changed. The table below explains how they correspond to one another:
| API Operator | UI Operator |
in
Is |
not_in
Is Not |
like_any
Contains |
not_like_any
Does Not Contain |
