OCSF Mapping for Custom Roles Events
This document outlines the mapping of Automox Custom Roles events to the OCSFClosed The Open Cybersecurity Schema Framework (OCSF) is an open-source, vendor-agnostic standard (Apache 2.0 license) designed to normalize security telemetry data. (Open Cybersecurity Schema Framework) standard. The following table provides a detailed mapping of each Automox Custom Role event to its corresponding OCSF class and event type.
Entity Management
New events are the mappings for organization role lifecycle operations: Create, Update, and Delete.
Event Classification Matrix
Operation Activity ID Activity Name Type UID Type Name HTTP Status Message
Create 1 Create 300401 Entity Management: Create 201 Organization Role Creation
Update 3 Update 300403 Entity Management: Update 200 Organization Role Update
Delete 4 Delete 300404 Entity Management: Delete 200 Organization Role Deletion
Actor (User) Information
Field Description Example Value
actor.user.uid Primary user identifier (UUID) of the actor 75c4039f-080d-477c-9eb2-af49d8f586ef
actor.user.uid_alt Legacy numeric user ID 67890
actor.user.email_addr The actor's email address admin@automox.com
actor.user.account.uid Account/tenant UUID 538f436e-51b0-48a5-80bc-ddbf6cc1baea
Entity (Role) Data
Common Entity Fields
entity.type Entity type classification "Role"
entity.uid Role UUID 550e8400-e29b-41d4-a716-446655440003
Event-Specific Entity Data
Field Create Update Delete
entity.name ✅ ✅ ❌ Not included
entity.data.description ✅ ✅ ❌ Not included
entity.data.permissions[] ✅*ClosedPermission: All permissions follow the {resource}:{action} format, such as endpoint:read ✅*ClosedPermission: All permissions follow the {resource}:{action} format, such as endpoint:read ❌ Not included
entity.data.scopes[] ✅‡ClosedScope: Scope is the enum of [ACCOUNT, GLOBAL, ORGANIZATION] ❌ Not included ❌ Not included
Metadata
Field Purpose Value
metadata.version OCSF schema version 1.1.0
metadata.tenant_uid Multi-tenant isolation identifier Account UUID
metadata.correlation_uid Links related events together The UUID of the target organization. This unique identifier may correspond to an account, a global organization, or a standard organization. It specifies the organization in which the role-related action is performed.
metadata.product.name Generating product name Automox Audit Trail
metadata.product.vendor_name Product vendor Automox
metadata.product.version Product version 1.0.0-dev
Raw Data (API Payloads)
The raw_data field preserves the original API request payload for forensic analysis.
Observables
Security-relevant data points extracted for threat detection and SIEM analysis.
Copy
observables:
                - name: "actor.user.email_addr"
                  type: "Email Address"
                  type_id: 5
                  value: "admin@automox.com"
                - name: "actor.user.org.uid"
                  type: "Organization ID"
                  type_id: 99
                  value: "b348aa75-c308-41e5-a1e4-26d56438a069"
User Access
New events are the mappings for user role assignment operations: Grant and Revoke.
Operation Activity ID Activity Name Type UID Type Name Message
Grant 1 Assign Privileges 300501 User Access Management: Assign Privileges User Role Assignment
Revoke 2 Revoke Privileges 300502 User Access Management: Revoke Privileges User Role Revocation
User Information
The user object represents the target user receiving or losing privileges (NOT the actor performing the action).
Copy
user:
                uid: "75c4039f-080d-477c-9eb2-af49d8f586ef"    # Target user UUID
                email_addr: "target@automox.com"               # Target user email
user.uid UUID of user receiving/losing privileges 75c4039f-080d-477c-9eb2-af49d8f586ef
user.email_addr Email address of target user target@automox.com
Actor (Unmapped)
The actor field isn't supported in version 1.1.0, but becomes available starting from 1.4.0.
For now, the field is stored under unmapped as a temporary workaround.
Once Automox upgrades to the latest schema version, it can officially include the actor field in User Access events.
unmapped.actor.user.uid Primary user identifier (UUID) of the actor 75c4039f-080d-477c-9eb2-af49d8f586ef
unmapped.actor.user.email_addr The actor's email address admin@automox.com
unmapped.actor.user.account.uid Account/tenant UUID 538f436e-51b0-48a5-80bc-ddbf6cc1baea
unmapped.actor.user.org.uid The actor log (logged on) b348aa75-c308-41e5-a1e4-26d56438a069
Resource (Role) Information
The resource object describes the role being granted or revoked.
Copy
resource:
                uid: "550e8400-e29b-41d4-a716-446655440003"  # Role UUID
                type: "role"                                 # Resource type
                namespace: "ACCOUNT"                         # Scope/namespace
resource.uid UUID of the role being assigned/revoked 550e8400-e29b-41d4-a716-446655440003
resource.type Type of resource role
resource.namespace Authorization scope ‡Closed Scope: Scope is the enum of [ACCOUNT, GLOBAL, ORGANIZATION] ACCOUNT
Privileges Array
The privileges array contains UUIDs of roles being granted or revoked in this operation.
Copy
privileges:
                - "550e8400-e29b-41d4-a716-446655440003"    # Role UUID
Unmapped Fields
Custom fields that don't map directly to OCSF standard schema but provide valuable context.
Copy
unmapped:
                scope: "ACCOUNT"                              # Authorization scope
                actor:
                user:
                uid: "832653b0-b57b-4d8d-8695-f0e8804de91b"
Field Description Value
unmapped.scope Authorization scope (ACCOUNT/GLOBAL/ORGANIZATION) ACCOUNT
Rationale: These fields provide Automox-specific context that enhances OCSF events for internal security analysis without breaking OCSF compliance.
Metadata
Copy
metadata:
                version: "1.1.0"                                       # OCSF
                version uid: "843f7ab9-1dd5-496e-8c5f-285927c3d976"    # Event UUID
                tenant_uid: "538f436e-51b0-48a5-80bc-ddbf6cc1baea"     # Tenant ID
                correlation_uid: "b348aa75-c308-41e5-a1e4-26d56438a069" # Correlation ID
                product:
                name: "Automox Audit Trail"
                vendor_name: "Automox"
                version: "1.0.0-dev"
metadata.uid Unique event identifier Event-specific UUID
metadata.tenant_uid Multi-tenant isolation Account UUID
metadata.correlation_uid Links related events The UUID of the target organization. This unique identifier may correspond to an account, a global organization, or a standard organization. It specifies the organization in which the role-related action is performed.
metadata.product.* Audit system metadata Product name, vendor, version
Observables
Copy
observables:
                - name: "unmapped.actor.user.email_addr"
                  type_id: 5
                - name: "unmapped.actor.user.org.uid"
                  type_id: 99
Observable Type Type ID Value Purpose
User Email Email Address 5 Requester's Email Identity tracking, anomaly detection
Organization ID Organization ID 99 Requester's Organization (logged) Event correlation, tenant isolation
